Holmey
- Jan 3, 2022
- 2003 Mercedes Benz E320 CDi 4 Door
Bought what I thought was a mint FSH 130,000 03 E320 CDi, but having trouble with it already
I intended driving down to Birmingham this morning with a friend, and when I got to his house and turned the key off and removed it, the engine carried on running, and when I managed to get the engine to stop, (by sliding out the front ECU connection plug in the fuse box), the key wouldn't turn, and the cooling fan was spinning away even with the key out. Also, when I tried to start it, the lights on the dash would go on when I put the key in, (and the cooling fan stop), but the key wouldn't turn. All the time, the steering lock was off. It also flashed up and SRS and ABS malfunction warning.
A quick google suggested the possibility that it was the battery, so I removed and tested the battery and not only found that the battery was not up to par, but wasn’t the right battery for the car, (it was too small/low capacity), so I bought and fitted a new correct battery for the car, (£180 – Ouch).
As soon as I fitted the battery, the alarm went off, but it would allow me to turn the ignition on and start the car, the problems being, it still wouldn’t turn off again, and when I stopped the engine by “pulling the plug”, the key wouldn’t turn again, the SRS and ABS warnings were still on and the only way I could start it again was by disconnecting and reconnecting the battery, something that would again allow the car to be started once, then everything back to how it was :-(
Any ideas guys? I can’t get it on any diagnostics until morning, but any suggestions/ideas welcome.
