2004 ML CDI 270 - problems -
Graham YUle
2004 ML 270 CDI
Can anyone help me - the alternator recently failed don my ML while driving and my battery got flat. Have replaced ALTERNATOR WITH NEW AND CHARGED BATTERY ,
Now the following warning lights have lit up and will not go off - BAS/ESP, ETS, ABS and EPC.
Is this just bad luck or will it be serious and how can i repair or check what is wrong.
G
Graham YUle
2004 ML 270 CDI
it may just be because the battery has been off pal , may just need the codes deleting
Tried that but th e technic could not get into the Codes with his laptop, so suppose will need visit the Mercedes garage in Inverness.
umblecumbuz
Wales and Gozo
Was the battery disconnected from the car while you charged it?
G
Graham YUle
2004 ML 270 CDI
Garage did it and do not think so
Taffy7hfa
Oxford
Try turning the front wheels from lock to lock a couple of times to reset the steering angle sensor, without power the ESP control unit might have forgotten its setting.
Steve@Avantgarde
Bristol/Somerset
Likely above. If you disconnect the battery it will loose the parameter for the steering angle sensor. DO the above and then switch the ignition off and on and the lights will likely go out.
