zenteknika
I have a 2004 sl350 with a catastrophic consumer drain on it - I was told it could well be linked to my alarm siren which no longer works and will require a new one as the battery acid will have knackered the old siren- shame they didn't design them to have a battery changed so it wont wreck the component- a new one is £105 and fitting another £120 so not cheap ! I think it needs coding to the car so cant do it at home mores the pity. If this is not the sole reason are there other reasons for a major drain ? I would be very interested to hear about Is there a designated sequence of tests you should do in order to narrow down the search and find the culprit? - I hear the electronics on these cars are a minefield to work through to fault find ! _ I already changed the battery for new but the problem persists-
