2005 c220 cdi drivers door trim Removal
garrard
SUFFOLK
C220CDI
hi everyone...am new to Mercedes ownership and trying to rectify some issues with the car i bought!.....already had a new turbo...bonnet release...plastic under arch trim!
Well i've got a rattle in the drivers door...obviously something loose.
I need to remove the trim to rectify the problem....do i need to know anything or does it just pop off like most other cars?
Any advice most welcome
Thanks in advance
G
garrard
SUFFOLK
C220CDI
  • #2
So its simple then is it? Should i have posted the question how do you remove the door trim? Can someone tell me how to do it.... that is the reason i posted the question
colechelle
Resigned
the pull handle, pop the front of that off, 2 screws, remove srs sign at the top, screw there, remove grill near the mirror, pull poppers all the way round card, unclip inside door handle cable, disconnect window switch at door control module, its really that easy!!!!
colechelle
Resigned
oh and welcome to the site, sure everybody just busy at mo!!!!
The SRS badge twist anti clockwise, If you have a cover over the mirror prise it off from the top and lift it out
Ellsy Tanners
Mars
Just to put my 2 penoth in!! there is a screw that holds the little piece of plastic by the lock!
G
garrard
SUFFOLK
C220CDI
thanks i'll try that.....looks like the same as most other door trims......what could the rattle be?........similar rattle in rear door but only hear them on uneven road surface
G
garrard
SUFFOLK
C220CDI
the problem was defective rivets holding the window mechanism to the door! repaired under warranty...fortunately
