Chuckles
- Mar 12, 2021
- 2005 G55 AMG, 5.5 supercharged
I replaced the conductor plate in the transmission. On the valve body there is a metal strap with a pin that fits in the slot of a shift mechanism up inside the trans housing. Also in the valve body there is a small white plastic plunger that slides in and out of the valve body. This plastic plunger has a slot molded in it. I do not see up inside the trans housing a pin or some other feature that will move this plunger in and out. I must be missing something. Can anyone help me out on how to position the plunger when installing the valve body/conductor plate assembly back up in the tranny?
Also it seems someone earlier worked on this transmission and failed to put back on the two plastic covers that fit over the solenoids. I can order the long cover but the short cover is not available from Mercedes in the USA. Anyone have any thoughts where I can purchase the cover.
Thank you
Chuckles
Thank you
Chuckles
