Like in video, any ideas?
It now takes about 3-4seconds before the engine starts with a puff of white/grey smoke (smells of burnt diesel). When the engine is warm, it starts instantly.
Certainly sounds like glow plug issues. Try operating your ignition 2 or 3 times before attempting to start to see if that helps any.
I had an issue last year where the car was fault code free but in cold weather it would turn over a few times before starting and then run rough for ~10s or so. After much faffing about and expense from mis diagnoses by my mechanic I eventually replaced the glow plug relay module at a cost of £100 supply only from Mercedes. 5 mins work and the car was like new.
