Dixyy
- Nov 4, 2023
- 2003 C215 and a 2006 C215
After replacing a flat battery today, the driver door module stopped working, so I plugged in STAR/Xentry and clicked on the driver door module, but there was a "couldn't connect error. I then inspected the front right SAM module for blown fuses but there was a fan-type noise coming from the module when the ignition key was in position 2 (just before start).
I have a second CL500 so, I checked to see if there was a similar sound coming from it, but it was silent. All the fuses were OK so I then tried pushing on the relays to make sure they were seated properly. When I touched the "Engine electronics/chassis relay". I heard a couple of clicks and the power going to the control module was restored, but when I got in the car and closed the door, power was again lost.
I swapped the relay with my other CL500, but it made no difference, to get power to my door module I need to give the "Engine electronics/chassis relay" a wiggle. Do I need to replace the SAM, or could it be a loose connection from under the SAM where the relay is plugged into, or something else?
I will upload a video of the noisy SAM once I find my phone.
