2007 Vito 111 Fan running when ignition off
JR Vito 111
Vito 111 2007 2.2 Diesel
Hi my 2007 Vito111 van is running down the batteries as its fan seems to be running after the van is switched off.
What might be the problem, is this common ?
Kev555
N.I
I haven't looked to close at my Vito but I'm guessing theres a temp switch on the radiator which controls the fan and thats usually the culprit in a lot of vehicles. If I'm wrong another member will probably point you on the right path JR
JR Vito 111
Thats great to know. I just bought it and its running the battery down and actually I hadn't realised it was the cooling fan that was running , thought it was the heater fan I was hearing .
Sent from my SM-G981B using Tapatalk
JR Vito 111
Thank you Kev. I took a bit of a chance on the van so hopefully this is one of only a few issues.
I think its clutch release bearing is beginning to grumble a little as well.
its drives pretty well considering its 2007 ad it has 410k kilometers on there ..I have a 2005 Sprinter 313 was well with 600K on there .
Kev555
N.I
Hopefully thats the fault with the fan JR. I only have my Vito about 3 years now. Quite happy with the van but had a few setbacks getting to this point. RWD makes clutch work a bit handier.
JR Vito 111
Hi Kev ,
I had a closer look at the van this evening The fan noise is coming from the ECU box to the left of the air box .
It seems to keep running after the van is stopped.
That can't be good . I.might put it back out as a post mentioning the ECU fan.( i assume its a cooling fan to keep the cards cool but I've not seen one cooling after the car/ van stops ).it might be best to plug it and see what error codes its throwing up.
I' actually don't have much experience of the vito . Have had loads of merc cars and the sprinter but the vito is a bit of an unknown.
Kev555
N.I
My fan runs on after stopping, cant tell you how long for or how long it should run, Probably until ECU is cool enough at a guess unless its on a set timer . I can hear mine inside behind glove box if thats the same fan? Are you sure thats what draining the battery? Did you check condition of battery?
MinionBob
SouthWest
Viano - 2012 - OM651 Engine - 2.2
I have just replaced an ECU blower fan on my van and I am 1/2 way through a 'how to' on it.
The ECU blower fan over-runs after switch off for approx 5-10 mins it appears, so is normal, but it should not be constantly on when ignition is off.
www.ckinsurance.co.uk
