Hi my SLK has failed its MOT with a cracked front coil spring and only the on side headlamp moves when the switch is used. Is the system run on vacuum? Because it's the light the same side as the broken coil Spring if it is vacuum run then it could be possible a pipe has come off? Any ideas anyone?
