200E Door Panel and Headlight Glass
plipplop
Hi all, Looking for advice how to get the door trim off the drivers door. I think the window glass has dropped of the runners a little cos its not closing to the very top.
Can the glass be replaced/removed from the headlight so I can remove the condensation from inside
thanks for reading
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
If the window closes OK but leaves a small gap at the top & makes a stuttering noise then the mechanism is worn out and you need a replacement regulator
The headlamp glass is replaceable after removing the whole headlamp assembly. Be careful with the reflector as the silvering is very delicate
Nick Froome
www.w124.co.uk
P
plipplop
Thanks for that Bolide, just need to work out how to get the door panel off now....
Thanks again Bolde for the quick reply
