Mike Chenery
- Mar 11, 2008
Hi I have a problem with a 1993 200e It starts fine runs fine but as the water temp rises to 60d it drops onto 3 cyl and stays on 3 until water tem gets to 80d it then most times clears and runs on 4 for the rest of the day if you leave it to cool down it then repeats the problem it has been into merc dealer many times but unable to sort It has had new fuel pump new filters new plugs dist cap rotar arm plug leads throttle switch temp sender I have taken it to a Bosh service dep they can find nothing amiss (HELP) i have hadit
Regards Mike C
Regards Mike C
