2011 ML 350cdi Code P0405
Jam60
2011 ML 350 cdi Grand Edition
Hi Everyone,
I have returned to the MB fold after having a couple of years with another make but have recently got an ML and initial thoughts were impressive however my problems are maybe just starting? Hope not.
My ML starts and runs fine for about 10 mins, after it warms up it appears to have no turbo boost and is very lethargic but usually No MIL light. The only time it put on the MIL light I plugged in my hand held scanner and it displayed the code P0405. On investigation this suggests EGR valve. On chatting to my Merc specialist He states that this is a bit of a rarity and can also be a pig to remove sometimes (He can't look at it for a week). I have studied how to remove the EGR and clean it but am having 2nd thoughts as this may be a waste of time? However I would appreciate anyone's experience of the above issue and advice?
mioba
Nottingham and Köln
If you are using a generic reader, I would get a second opinion.
Going through the efforts to remove a faulty valve to clean it, only to put it all back together and find it doesn't work will annoy you. That said they do clean up well.
Your call, cost of new v being confident in a clean up.
Jam60
Just a quick update. Had my ML in for diagnosis at Merc specialist Good news & Bad. I was correct in my original diagnosis it appears to be The EGR valve. Sadly they are a bit like rocking horse poo at the moment ie unavailable from Mercedes UK at the mo.
ajlsl600
france
That's cos of dtf and many defective. Recycling exhaust n other combustion gases thru electric, electronic controlled valve a sure remedy for. Expensive disaster. Plastic inlet manifolds another.
Take it out and clean it buddy , I do mine every year . 30 minutes work maybe .
This may help
(it’s from the other side ;) )
This was the one I was looking for
Jam60
Thanks for the info Wighty. Merc man said He took it off & cleaned it, also said it then started leaking water which He repaired. Gasket I presume? Going to bite the bullet & get it mapped out as Merc can't give a timescale of EGR availability.
Jam60
Out of curiosity does anyone have a part No for a water cooled EGR valve gasket please?
supernoodle
E220 2005 2.1D
Isn't P0405 Exhaust Gas Recirculation Sensor “A” Circuit Low? That sounds like the feedback from the position sensor is below normal range rather than anything mechanical. Open circuit would give a circuit low too.
Jam60
That's what my scanner diagnosed A circuit low wasn't sure if mine was accurate hence taking it to s Merc specialist who diagnosed the EGR pooped.
mioba
Nottingham and Köln
I wouldnt map it out. Thats just circumventing the issue.
A clean up and your car is in order.
Just my tuppence.
Jam60
As stated previously the EGR is at fault and looks like availability is an issue at this time so mapping it out is my only choice at present.
Jam60
Update: Had it remapped inc programming the EGR out. Done over 500 miles and have to say I'm impressed. Cheaper option than the Unavailable EGR valve, smoother & more powerful delivery when required and improved fuel consumption indicated but I'm sceptical about the reading???
However I am pleased with the results and saves running around in limp mode with the potential to bugger the dpf as well!
ajlsl600
france
