Hi all,
Was hoping someone on here can shed some light on an annoying intermittent non-starting issue we are experiencing on our 2011 W221 S350 CDI.
On the odd occasion the car won't start. All the lights on the dashboard come on but when you turn the key nothing happens, the car won't crank at all. When this occurs the yellow 'ESP inoperative' and 'run-flat tyre inoperative' messages come on. In addition to this, I have also noticed a curious pattern that everytime this fault occurs, the glow plug light doesn't illuminate when you attempt to start the car so much so that I now know that each time I attempt to start the car and the glow plug light comes on, the car will always start and exactly the same will happen vice versa i.e. if the glow plug doesn't come on at the starting phase then the car will not start.
We have replaced both starter relays in the fuse box located in the engine compartment but this hasn't helped. We've taken the car to a local garage with STAR but no faults were found relating to this issue. We have been advised that this may be an ECU fault or a fault with the EIS but was hoping some of the knowledgeable chaps on here can point us in the right direction instead of going down the route of attempting expensive guesswork repairs which is where we seem to be at the moment.
Any advice would be most appreciated.
Joe
Joe
