2012 E350 CDI dpf cleaning
Sr108
E class
Anyone have experience doing this yourself ? I’ve seen videos of people squirting dpf cleaner into the pipe where the pressure sensor plugs in , anyone done this ? Do you need some kind of gun to squirt the liquid in ?
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Seriously don't waste your time until you know the dpf sensor is working or not , it sends false information to the ECU that the dpf is blocked , when infact it's the pressure sensor that's no good.
Sr108
E class
What’s the cheapest and easiest way I can check the sensor ? Is there a device that’s cheap that I can buy ? Don’t wanna waste money paying someone just for a 2 minute job..
onefortheroad
uk.
Icarsoft mb2 . Used ones on the mb forums are around £80 . Or ask on here if anyone's local to you who has a one .
mioba
Nottingham and Köln
DPF will clean themselves provided the sensors are working.
What makes you inclined to clean it?
Sr108
E class
See the pic I attached of the fault codes
Sr108
E class
supernoodle
E220 2005 2.1D
The proper way of testing any differential or absolute exhaust pressure sensor is with something like a MityVac, a pressure source.
The mityvac isn't cheap but there are cheaper alternatives.
With such a device you can compare the pressure reading on the diag tool against the gauge at several points.
Sr108
E class
Can you help me where I can find them ?
onefortheroad
uk.
Sr108
E class
you can always swap out the sensor and see if it works - I did mine last year got a bosch one for around £30 from Amazon, car been fine since.
Bosch 0 281 006 278 Air Manifold Pressure/MAP Sensor on Amazon - £33.
Very easy to change - takes around 20mins.
Yeah was thinking about this , want to get a scanner first and check it first though as someone mentioned previously .. would be good if I could find someone nearby who has a scanner to check the sensor
onefortheroad
uk.
What about the v 1.0 ? Would that not work ?
Possibly . Check out the icarsoft website . It'll list what it covers .
Sr108
E class
  • #18
onefortheroad
uk.
