2013 c220cdi thermostat
Chr1sd
2013 W204 C220cdi AMG
mioba
Nottingham and Köln
Cant think it will be difficult provided you know where the stat is.
Disconnect associated gubbins. Have a pot handy to safely collects spills (also if you intend on re using the coolant).
Remove and replace stat in correct direction.
Put it all back together.
C
Chr1sd
I was wondering if there was any special requirements for bleeding the system afterwards.
mioba
Nottingham and Köln
Self bleeding if I recall. just keep an eye on the level once it burps.
If you put in what you take out it should not be an issue!
C
Chr1sd
Thanks.
Sent from my CLT-L09 using Tapatalk
onefortheroad
uk.
Park facing uphill. Use a turkey baster to empty header tank.
Tel: 020 8863 9233
