Pauld1000
- Nov 14, 2020
- 2013 C350d Coupe
I am hoping for some advice!
I drive an 80 mile round trip each day for work, mix of A roads and dual carriageway, so am confident the car would be able to regen on its own normally.
I had a P244a7 code come up a few months ago, and replaced the DPF sensor with a Bosch one. This seemed to fix it for a few days, then it came back intermittently.
Fast forward and I bought the Icarsoft Pro to try and regen it, and the above code has stopped occurring, but now the car is in limp mode constantly, with a code of P246309 'Soot content of the DPF is not ok, there is a mechanical fault'. I've put a new Mercedes DPF sensor on, no change, stripped out and cleaned the DPF, no change, stripped out the EGR cooler, and checked the EGR valve isn't blocked (blackened but not sticking). checked vacuum operation of the valve with a mityvac, and this also works.
The diagnostics are still showing the DPF at 359% and wont allow a forced regen. I have tried resetting adaptations, (mainly has a comms failure), and managed to get it to 0.3 briefly, then it jumped back to 350+%. Also managed to get it to read 185% briefly, started the forced regen and went for a drive but aborted as it was showing a message of 'the test has not yet been started', showing DPF again at 358 (and rising slightly through the drive).
With the live data, I took it out earlier, and did notice a couple of possibly odd readings (although I am not sure what different sensors 'should' read. Readings were:
B60 Exhaust Back pressure I had 3.68Bar (in limp mode) at one point.
B19/9 temp sensor upstream of DPF - 166°C
Air Mass 1063mg/Hub
B28/8 DPF diff press sensor - 0.02bar
B11/4 Coolant temp sensor - 95°C
B19/9 temp sensor upstream of DPF - 306°C
Engine speed - 2698.5rpm
Injection quantity 16.89mg/Hub
Fill level of DPF - 358%
Soot Content - 10g
Ash content - 0g
total distance at last correction of Ash content - 160534km
Y27/9 EGR actuator - 50%
I have also noticed that the Y27/9 Exhaust gas recirculation actuator seems to always sit on or very near to 50% at idle? sometimes goes up to 85% initially then drops down. Physically checking the actuator rod to the valve, this seems to be in one position engine off, and the far opposite engine on?
I'm kind of getting fed up of trying to fault find to be honest and was hoping the above might allow someone with more knowledge to point me in the right direction! I am fine stripping and rebuilding, but not at figuring out what I need to take apart!
Anyone have any advice on what to try next?
Thanks in advance
Paul
Air Mass 1063mg/Hub
Soot Content - 10g
Ash content - 0g
Thanks in advance
Paul
