2015 220cd AMG
richard3009
This car is driving me mad. Four times it has been into the garage in limp mode for DPF excess soot code. Independent says soot level is nowhere near high level. Resets all parameters runs fine for about 4 weeks then bam straight back into limp mode. Runs spot on for about four weeks before failing. The annoying thing is the garage shouldn't be charging for failed, attempt but they spin the yarn we have run a complete diagnostic sir, zzzZzzz
Hello and welcome,
Find a garage that knows what they're doing... where are you based?
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Have they changed the dpf sensor ?
R
richard3009
Sensor not been changed based near Scunthorpe
onefortheroad
uk.
R
richard3009
We can't just assume it's the sensor, mechanic told me it was returning normal readings, how he knew this I don't know. Just noticed how cheap they are going to replace it myself. I have the icarsoft Mb v. 02. So should be able to clear the fault afterwards.
onefortheroad
uk.
This is the way.
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
Please find herewith, copy of readings of Live Data from my iCarsoft MB v2.0 associated with a 'check DPF' function from a cold engine just after startup, as you can see there are readings from 12 replaceable items all of which, if out of parameters will inhibit a DPF Regen, such as sensors/functions that when you find replacing one of them doesn't fix your problem, you have another 11 to go after one by one. Good luck with that! OR...
Sell your scanner to someone who knows how to use it and with the profits, contact Richard Hollings in York and use your money wisely! :)
BENZ_EN_TEST_00027>C(204)>Diesel>204.002 - C 220 CDI>Manual>ECM - Engine Control
Module(CDID2-CDID3 for Combustion Engine OM651 (N3-9))>View Data>Check diesel
particulate filter:
Total Frames: 1190 , Supported Items: 14
Frame 1/1190:
B60(Exhaust back pressure sensor) ----- 1.26bar
B19/9(Temperature sensor upstream of diesel particulate filter) ----- 34°C
Air mass ----- 649mg/Hub
B28/8(Diesel particulate filter differential pressure sensor) ----- 0.01bar
B11/4(Coolant temperature sensor) ----- 4°C
B19/11 Temperature sensor upstream of diesel particulate filter) ----- 153°C
Engine speed ----- 963.75rpm
Injection quantity ----- 8.90mg/Hub
Main odometer reading ----- 84302km
Fill level of diesel particulate filter ----- 95%
Soot content of diesel particulate filter ----- 3g
Ash content of diesel particulate filter ----- 0g
Total distance at last correction of ash content ----- 83910km
Y27/9(Exhaust gas recirculation actuator) ----- 50.29%
onefortheroad
uk.
B28 is easy enough to check for a pressure reading . In most cases changing it cures the problem . The rest is a domino effect as far as errors go.
A true clogged dpf won't respond to changing anything I don't suppose. But b28 is a good starting point , cheap and easy to change. It's also a common issue with mb's.
R
richard3009
Chassis number WDD2043022G407661
What's my part number for a dpf pressure sensor
