2015 E220d S212 P247115 error code
Meguinness
2015 E220d S212
hi guys ,hope you can help me figuring out how to solve this problem , ...MIL light will come up after few restart ...after clearing errors obviously is coming back....
Im testing all the temperature sensors using xentry...the only one not able to communicate with is the B19/7 ....even if xentry is pointing P247115 error code to B16/15 that i tested and working fine.
any clue where B19/7 is located?
vin: WDD2122012B197777
thanx
In the exhaust manifold under air box.
M
Meguinness
2015 E220d S212
Tested both sensors and working ok....non of them are SENSOR 4 , so will look at the one past the catalytic converter....as that what Xentry says that is the faulty one even when tested with Xentry it showing working.
I assume is accessible by removing the engine undertray ? Ta
This test screen shows its faulty.
Yes it's a straightforward change
Looks fine!
Where is the fault code on Xentry? You show every screen except for the fault code
Probably faulty sensor.
Second screens shows substitute values will be shown if there is a current fault code
M
Meguinness
2015 E220d S212
Sorry..can you please explain better for me Thank you
supernoodle
E220 2005 2.1D
If ever you're unsure which sensor is which, just unplug one and see what codes you get.
As you already have an open circuit fault, if you got the correct sensor you won't see any new codes.
If you got the wrong one you'll now have two open circuit faults. Plug it back in and try another.
Buck2003
2011 E220 CDI 2.1 diesel blue efficiency Auto Cabriolet
I'm no specialist but would if thought 2° difference between those values would be within tolerance.
As for the other messages I don't believe a thing Mercedes tell me via OBDll...I mean a head light fault causes a glowplug DTC faults and warning screens and so on.
