202 headlight flasher problem
spc
hi all,can any one shed light [no pun intended]on a problem im having with my 1994 202 diesel headlight flasher,it started working intermittantly a few days ago, then yesterday as i checked it in my garage it came on then went dim and has not worked since,as i believe the flasher to be a very important safety aid i would like to sort this asap,is there a relay that could be at fault,or if not,and i remove the switch would i be able to get inside it to clean contacts,all help gratefully recieved,thanx for your time.stan.
Have you checked the fuses Stan
MissyD
Essex init
www.depop.com
E200 1993, E300 Coupe 2019
Hi, BigAsotonUk (borrowing missyd's PC).
As Malcolm says first things first try the fuses, then I would be inclined to see if you can clean the switch contacts as this has been a common fault on this type of car.
Thats interesting,,borrow some ones computer :rolleyes:
any one could be anyone, must check mine:-D
spc
thanx for the fast replys,yes malcolm ive checked the fuses,how do i go about cleaning the contacts?
spc
headlight flasher
hi malcolm,stripped the wheel off,squirted some brake and clutch cleaner into the base of the stalk and hey presto after a couple of goes the flasher started working again,thank you all for the suggestions,many thanks,stan.
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
I thought brake cleaner melted plastic!!, I hope i,m wrong.
spc
hi,yes unit is stamped abs.
bongser
lancashire.uk
c- class elegance 1995 220diesel automatic
hi malcom.had same problem with my w202 d 1995.i found your post and squirted one short blast of wd 40 intothe hole around the flasher stalk, and hey presto it worked straight away welldone .
