204 headlight upgrade
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by PeterCLK, Dec 18, 2012.
  1. PeterCLK
    PeterCLK Senior Member
    707
    May 14, 2008
    Cumbria
    Your Mercedes:
    2012 204 Elegance saloon 220 cdi
    I've just bought a 2012 c220i elegance facelift model with standard headlights.
    These I find poor and wonder if it is possible to upgrade in any way?
    The car is 6 months old so I would not want it to affect the warranty.
    thanks in advance for any advice.
  2. whitenemesis
    whitenemesis Senior Member
    17,978
    22
    Dec 21, 2006
    Your Mercedes:
    CLS55 AMG '05
  3. television
    television Always remembered RIP
    164,074
    309
    Your Mercedes:
  4. NW_Merc
    NW_Merc Banned
    801
    Apr 27, 2008
    Oop Norf
    Your Mercedes:
    Mercedes W202
    Which ones do you need? H4 or H7?
  5. television
    164,074
    309
    Your Mercedes:
    They can all be bought for that price on Ebay
  6. OP
    PeterCLK
    707
    May 14, 2008
    Cumbria
    Your Mercedes:
    H7 for both main and dipped beam.
    Would you replace both?
  7. television
    164,074
    309
    Your Mercedes:
    A hard question as I do not use the mains that much, I changed both on my CL140, but only the dipped on my V70R.
    If there is any down side the life is not as long as normal bulbs.
  8. Chrishazle
    Chrishazle Senior Member
    3,601
    1,201
    May 25, 2009
    Nr Ashford, Kent
    Your Mercedes:
    I changed both on my S204 - and do not regret it.
  9. whitenemesis
    17,978
    22
    Dec 21, 2006
    Your Mercedes:
    CLS55 AMG '05
    The cost is insignificant over the life time of the bulbs, so I would always replace both ;)
  10. drivemycar816
    drivemycar816 Active Member
    28
    Nov 17, 2012
    Your Mercedes:
    2004 E320
    I hope these links will help. These are H7 upgraded headlight bulbs. Click 1 or 2 .
  11. OP
    PeterCLK
    707
    May 14, 2008
    Cumbria
    Your Mercedes:
    Fitted them today and they are much improved.
    Thanks for all the advice and links.
  12. rhud
    rhud Senior Member
    686
    5
    Mar 11, 2008
    Your Mercedes:
    A160 BlueEfficiency Avantgarde SE 2010
    Slightly off topic - although I find headlights ok I am underwhelmed by the dim reversing lights, which don't show up anything,other than warning others. Is it possible to upgrade these, too?
  13. television
    164,074
    309
    Your Mercedes:
    Interesting question, not sure if they are part of the warning system, one has to consider the wiring size as well and components in the switching. LED maybe
  14. whitenemesis
    17,978
    22
    Dec 21, 2006
    Your Mercedes:
    CLS55 AMG '05
    LED will work with compensating resistors or CAN compatible lamps. AFAIK 21w is the max one can show to the rear
Share This Page
