210 Estate - Rear Fog Access
Profuminif
'02 E240 Estate
to get to the rear fog lights to change bulbs, is it just a case of un-doing the two bolts that are visible? or are there any other fixings?
many thanks on advance
simon
turbopete
Spennymoor
2022 '71' Ford Grand Tourneo Connect (sorry)
i would have thought there would be a flap or trim that opened in the tailgate trim and you just access them through the openings. the bolts will hold the entire lamp to the tailgate. thats the norm for most cars. mines a saloon and although the trims are missing it seems, thats how they are accessed on my car.
230K
Belfast
E300TD/1998/3.0 Diesel
From the owners manual... "We recommend that you have the bulbs of the reversing lamp and rear foglamp changed by a Mercedes-Benz Service Station"
I will have a look and see what is involved
230K
turbopete
Spennymoor
cant really see what would be different about the estate compared to the saloon! as long as the right bulbs are installed so that the warning light goes out on the dash, their nothing special as far as im aware!
230K
Belfast
You need to remove the interior trim which is pops along the bottom and up the sides, screw at the pull handle remove handle trim and then the whole trim lifts up. Once inside i think there must be an aperature to get at the bulbs, if not undo the 4 nuts to pop the light out.
Hope this helps.
230K
turbopete
Spennymoor
as i expected. accessing them may be different to the saloon, but nothing special about changing the bulbs
P
Profuminif
'02 E240 Estate
cheers guys
i will have to hope for some nice weather over the weekend to attack the rear trim then
Simon
