ted collett
- Mar 11, 2008
I'm a new owner of a 230SLK Auto and not being used to automatics am a little dissapointed in its behaviour, seeming to be a bit sluggish and slow to respond to gentle throttle inputs, so I'm not sure if its just me or a problem, from what I've seen on this site it looks that, although it has only done 47000 miles, an oil change might be a good first move.
However in order to understand more of how it can be used and therefore get the best out of it, is it possible, at certain times, to treat it as a manual ? i.e. by starting say in 1 or 2 and changing up when I want to rather than automatically. Similarly when I approach a corner in a manual I would change down and accelerate through. Can I do the same with this box i.e. if I'm in D can I push it into 4 or 3 and accelerate through the corner so that it doesn't either change down or up automatically in the middle of the bend ? Also if I want to overtake in a manual I'll select a lower gear and wait for the oppurtunity to go past. Can I do the same as above, select 4 or 3 in anticipation and and accelerate when I'm ready. Rather that kickdown and perhaps be too early and it'll change up as I ease off and have to do it again as the next oppurtunity arises, or leave it longer and be too late because of the delay taken for it to change down.
