230TE W124 gasoline - co level too high
VAngsoe
Hi guys,
I am new to Mercedes, but i am an old mechanic.
I´v got this 1991 230TE W124 - done about 200.000 kms. Runs like a beauty.
At MOT i did not pass, since the Co level at idle was about 3,5 percent. Its only allowed to be 0.5 percent.
As soon as it gets a litle revs, the Co level drops to 0.1 percent.
I changed air-filter and spark plugs. O2 sensor and cat are fine.
The engine sounds great even at idle.
Is there any way i can adjust the Co level at idle ?
Which sensors affect the Co - AFM - at idle ?
Tks a million guys
Vangsoe
BillN_33
Hampshire
1992 300CE and 1990 300TE
If all else fails - I read on a US site that you can buy an additive that will reduce the CO2 so that it get through the emissions test.........they seem to user it for "oldish" cars that have problem with their test
Stick it in about a quarter of tank of fuel........have the MOT done....reading fine.........them back to normal after it has been used
Maybe if you do a search on a few US W124 related sites
Sorry that I cannot be more specific
Lock it into second and do a high speed run (Italian tune up) just before the test, I had to do this on my 300TE in Sweden to get it through the test at 1 year old
star
Reading
Smart + others :)
This would be a 102 engine equiped with a cat and is not subject to the full cat test, it is also adjustable with a 3mm allen key.
Number_Cruncher
1995 W124 E300D TE
I suspect the motor car isn't in the UK, and possibly isn't a UK spec car, and may be subject to defferent regulations.
star
Reading
Smart + others :)
true. :) but still adjustable unless later ingine fitted.:(
Number_Cruncher
1995 W124 E300D TE
Possibly - but, the OP mentions an oxygen sensor and cat. I wouldn't expect to find any adjustment on such a car.
At about this time, cars for other countries, notably Sweden, were equipped with fuel equipment that was more advanced compared with what was available in the UK.
Perhaps the OP could clarify the situation?
star
Reading
Smart + others :)
early attempts at closed loop systems were adjustable as they only bolted a cat and lamda to a standard KE system. need to know what engine is fitted. (102 or 111) :)
The CO level should be 1,0 + or - 0.5% this will be the 102 with KE and the adjuster with the 3mm key for CO levels
meanie
Oxon
If it's adjustable,it will be adjusted as in the attached pic.
The aperture will be through a raised 'tower' which should have a small plastic (blue or yellow) bung in it.
And impossible without an exhaust analyzer
cant use exhaust analizer due to cat, voltmeter via the dianostic socket.
All of the info that I have says on a meter, I have done them on a meter successfully
roofless
w124 e220 estate
it's a probe up your pipe at the mot test
I could do that myself.
Would I be too cheeky to ask for a howto?
Would need to know what pins on the socket and what reading on the meter.
Tony
I have never seen any reference to doing this on a volt meter and I do not see how this can be the case, you are adjusting what comes out of the exhaust, and this is where the analyzer probe sits
Number_Cruncher
1995 W124 E300D TE
Star is (possibly!) right - however, it all depends exactly upon which country the car was built for - which the OP hasn't yet told us.
The mixture adjuster in KE jetronic has a much wider adjustment range than the lambda sensor, so, you do have to adjust the mixture on cat equipped KE cars, to get the mixture in the range where the lambda can control it to be around stoichometric. The voltage you're checking is effectively making sure the lambda sensor spends a certain proportion of its time at the weak end compared with the rich - it's almost like a dwell setting.
The question I have with adjustments is, what has happened to the system to require an adjustment? Unless there has been a major part replaced or if there's a fault, the adjustment will never become too far wrong. If it is a fault, it's better to fix the fault, and then check the adjustment.
The reason why one would generally adjust KE cars using a gas analyzer, is that KE plus cat was a short lived combination in the UK.
I have never seen any O2 sensor adjustments on a KE but I will take a look as soon as I can
