[Wanted] 245/40/17 Winter Tyres
Vx-Man-G
C-Class CDI
Hi guys.
Just preparing for net winter, so seeing if anyone has a pair of Winter 245/40/17's available?
Would consider buying a set of wheels if needs be.
Thanks,
G.
Chrishazle
Nr Ashford, Kent
Seems to be an uncommon size - it's what I have on my S204, searched the other day for all season tyres, can't find any in that size! I think I found a couple of winters on Tyreleader though - but as I have a set of 16" winter alloys that didn't help.
Vx-Man-G
Vx-Man-G
C-Class CDI
How will downgrading to 16" in winter affect the car setup, in terms of TPMS? It throws a wobbly anytime there is a slight deviation away from normal PSI.
Chrishazle
Nr Ashford, Kent
The 16's have the same rolling radius as the 17's, OK the TPMS flashes up straight after the change, but it's just a case of telling it the tyre pressures are correct and it's happy - until 1 of the 16's looses pressure so the rolling radius changes - the TPMS on my car does not actually measure tyre pressure, it monitors rotation speed of each wheel (like the ABS) and warns when a wheel is going a different speed, presumably for a while rather than immediate reaction or it would go off too often.
The benefit of 16's in snow is that the tyres are narrower.
My Clk rears are 245/40/17 I believe , in the winter I use 16" steel wheels all the same size with 205/55/16 . No problems with any tyre warnings after the tyre thingy is reset .
The SL SHOP YOUR ONE STOP SHOP FOR ALL THINGS SL, SERVICE & RESTORE, SALES, HIRE & PARTS
Choose from a wide range of superbly prepared SL’s each with a 12 month guarantee. We can service, update, re-trim, restore and repaint your 107 SL.
Choose from a 6 or 8 cylinder car for the day, the weekend, a month or a year. Contact us for a wide range of parts. Tel: 0844 414 2116 or visit our website atwww.theSLshop.com
