spock500
If it's still stuck perhaps try the following.
Heat the head using a heat gun gently around the injector. This should be sufficient for the alloy to expand whilst the denser steel remains comparatively cold.
When the area is heated sufficiently apply a wrench but do not turn. Instead, squirt directly at the injector with freezing spray whilst applying pressure to the injector.
You might need a budding assistant for this manoeuvre
