300 TD pipe block to turbo pipe weaping oil
Gaz69
Hi Guys,
I've been cleaning and tinkering around the engine of my TD300 and noticed the little pipe that heads from the engine block to the turbo pipe, is leaking oil at the block.
Is there a gromit the needs replace or is it something more serious. The pipe is loose at the block too.
Gary
Parrot of Doom
Manchester
Presuming its a W210, you mean this?
If so, you'll find the leak is very likely oil vapours. There is an oil separator under the black engine cover, there are a few connections, on mine one of the pipes had split. I just used self-amalgamating tape to fix it.
The pipe is supposed to be loose enough to pull out, but not loose so it rattles around.
dieselman
A diesel
The OP means the turbo drain back to the sump. It shouldn't be lose, just tighten it up and replace the gasket if necessary.
G
Gaz69
Yes that's the pipe in question. Thanks guys, I'll have go at it over the Christmas holidays. Merry Christmas and a Peaceful New Year to everyone here on the forum. Catch up with you all in the 2008
