Hi All,
Just signed up in the hope someone can help me. My uncle has a 1992 J 300Ce 12v. It developed a problem where when it would reach operating temperature, it would misfire and then stall. If you tried to start it again, it wouldnt. Leave it 10 mins and it would fire up again...2/3 mins later, stall again.
Anyway, the car has been stood for about 4 weeks and now it will not start even from cold - same sort of performance trying to start it now, as when trying to start it from hot when this problem first occured.
There is plenty of spark at all 6 cylinders. Fuel delivery upto the injector pump is fine, but then there is virtually nothing pumped from this to the injectors. The occasional drip, but nothing more. I have removed the pump and am due to send it away for inspection.
Just after any experience of this, and whether any of you know of any other problems it could be. There is what looks like a cold start injector and when I undid that, fuel came out at the correct pressure. The other 6 lines tho produced virtually nothing.
Never worked on a Merc before, but know my way around an engine bay, and wanted some advice before I send the pump away to be checked and possibly replaced/reconditioned.
It has come to me after 3 garages have failed to locate the problem after replacing various sensors etc.
Any help will be much appreciated.
Kind Regards
Paul
Kind Regards
Paul
