My 300ce has been a pig to start recently - the basic symptoms are when trying to start it will crank away but not fire - until i release my foot from the accelerator when it will then attempt to fire and chugg for a a short time then die. A big puff of smoke will often then be released via the front grille - coming out of the air intake/box. With many repeated attempts it will enventually start - when running it drives without fault. But when stopped it will again be a nightmare to get it running again.
So i have had a mechanic friend over to view the 300 again and he states ... 'that is definatley a timing issue, as tho it is 180 out. Basicly the timiming is firing in the wrong order eg. when the inlet valves are open' Please note he has NO experience of mercedes engines. Please can anyone advise if it would appear to be a timing issue? and also if replacing the crank position sensor would be the most sensible port of call to rectify this problem?
I have posted previously on this matter and was advised that 180 degree out 'tends to be only possible on non-inteference engines' so I am abot confused - can someone pls help me out.
Regards Fraz
Regards Fraz
