Right, it sounds to me like your idle air valve is not work properly.
These things are expensive, but in most cases can be brought back to life with a bit of carb cleaner, care and wd40.
It is located underneath the air filter housing, and is silver cylinder with an electrical connection and two approx one inch diameter black rubber hoses connected to it.
Remove it from the car, blast the insides with carb cleaner, carefully prod the slide valve mechanism with a screwdriver and make sure it is free moving. Then lube it up with WD40 and refit.
Failing that, contact someone like Mercman for a second hand unit.
My parts catalog says it is A 000 141 22 25 and the cost is scary, over 150 :-(
As for cruise control, how long do you have? It could be loads of things, but in most cases it is either a problem with rear brake light bulbs or the amplifier unit has dry solder joints.
