This should suggest that possibly the lighter has a poor or burnt connection as the radio and lighter both use the same yellow cable, I am very sure on this point
ive disconnected the cigarette lighter so the block connector is loose ive put a test light on and no power if I take radio out and find the yellow wire can i tap into it and run another wire to the cig lighter to run the sat nav. thanks
The wire comes from the ignition switch as they are both key 1 and key 2 I will check to be sure tomorrow on the wiring,,this could be tied up with the fan fault
