300SL Wiper Problem
R
Raz53
Hi guys, I own a '91 300SL and have a wiper problem. It only occurs when I turn the wipers on "intermittent". They work irregularly, and after a few "swipes", they stop. Even when irregular, it stops at random locations across the windshield. I can push the switch and get it to move and eventually get it back to its "parked" position. Oh, if turned on to wipe in the regular mode, it works perfectly.
Any ideas?
Raz
Hello and welcome, a good dose of switch cleaner should sort that out in the switch
R
Raz53
When I said "switch" I'm referring to the steering column mounted stalk control.
Thats the one that needs to be cleaned, it should solve the fault
