Standing in front of the engine. Look to the right of the engine between the steering pump and the engine block. You will see a long nut (13mm). Remember it. Look down at the fan belt and at the tension wheel (plastic). To the right of that is a 17 or 19 mm nut. just above that is a graduated scale with a pointer. Ok so slacken the 17 / 19mm nut a couple of turns. Then remember the 13mm long nut? Tighten that till the pointer on the graduated scale goes to the right. When there tighten the 17 / 19mm nut and job done.
Stop looking for the Best Garage!! We are here
and have the best advanced solutions for you,
at Competitive prices.
Put us to test with any issue you may have.
