my 311 sprinter has recently developed a fuel leak on the injection pump. I am wondering if there are some seals i could replace instead of buying a reconditioned pump.
i,ve stripped one off and found some loose allan bolts on the inside off the pump secure the bolts and refit.check before you build it back up it worked for me.54 plate 311.
