315 sprinter limp mode
markyni104
New Registration
sprinter 315
hi I have a mercedes sprinter that drives ok until around 2.5k rpm then goes limp mode ,
I have a few codes p1955, also def pressure high pressure , also turbo underboost , has anyone drilled the def out as the garage said its probably stuffed , also they did a smoke test on the intercooler system and no leaks in the boost system so they said possibly the turbo its a twin turbo too ! do you think I should bite the bullet for a new turbo and drill the dpf ?
