320 CDI Throttle
jerryhaslett
I have a 2002 320 CDI, it suddenly refuses to exceed 3000 rpm, is very low on power and refuses to kick down, I feel it is a throttle problem, it is just as if the car is only registering half throttle even if the pedal is to the floor. Any ideas???
Hello, it will be the MAF filter that needs to be replaced, this is a standard fault 99% it is the MAF.
Malcolm
Most definitely the MAS (MAF)
jerryhaslett
S320 CDI Throttle
And where would I find the MAS (MAF) Filter chaps, sorry not too technical!:confused:
jerryhaslett
If you are refering to the air filter, changed that on Friday, no difference, also changed fuel filter.
Ultymate
N. Wales
C230K Estate 1998
The Mass Airflow Sensor (MAS) is situated in the ducting between your airflter and the engine has a loom connection to it and is usually held in place by a couple of Torx screws which may be of the security type, hope this helps;)
jerryhaslett
Mercedes S320CDI Throttle
Thank you chaps, car now going normally again. Your help was very much appreciated (and needed).:p
