320cdi-2000-climate control illumination
kenethw
all backlighting to the control panel has been "lost" [dozen push buttons no knobs]-how do i repair please
K
kenethw
no knobs only push buttons-thank you anyhow
K
kenethw
chassis wdb2102262bxxxxxx 320 cdi avantgarde auto estate-hope that helps you malcolm-ken
K
kenethw
thanks malcolm but how do you remove the panel\unit without damage,is it just held with hidden clips?
To little slots one each side
you need keys
W 000 589 88 63 00 and cost £1 from MB
colechelle
Resigned
two screws inside above the radio and 2 at the top of the outlets for vents, if memory correct!!!!
K
kenethw
thanks for advise,tried to buy keys but mb will not supply"tools" can anyone supply photo/drawing showing dimensions please;i assume they are no more than a flat blade which is pushed in and releases a tang by moving it up\down\sideways?
