320cdi thoughts on this please ?
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by bembo449, Feb 14, 2020.
  1. bembo449
    bembo449 Senior Member
    4,154
    1,285
    Jan 2, 2012
    gainsborough , lincolnshire
    Your Mercedes:
    w221 320cdi , r170 230k , land rover discovery 3 , insignia vxr , shitron dispatch
    car sounds louder than usual would be and by that I mean the turbo , ive checked the vanes , they are free and no bearing play at all , so could this be a failed port short off motor not operating the flaps , restricting airflow OR a blocked CAT ?? any data I can look at to try and nail this down ??
  2. Blobcat
    Blobcat Moderator
    19,181
    6,249
    Near Grange Moor (not Wakefield...)
    Your Mercedes:
    R171 SLK280 3.0, Land Rover 110 County SW
    Hole in the exhaust?
  3. OP
    bembo449
    4,154
    1,285
    Jan 2, 2012
    Your Mercedes:
    no pal its sound , I reminds me of back when I mad the ML , the cat collapsed and it sounded just like it , got to be a way to check on live data surely ??
  4. LostKiwi
    LostKiwi Senior Member
    21,428
    10,880
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    Diagnostics can only detect such things by inference (e.g. does not match throttle position) or by direct feedback from operation (e.g. a switch or sensor operated to confirm something operated as it should). I'm pretty sure there is no feedback from either swirl flaps or turbo so no chance of seeing it reported. Checking by inference will only show an error if the results go out of spec (i.e. seriously wrong and then only if the ECU is programmed to look for it). You may be able to calculate expected airflow for a given throttle position and go from there but it won't be easy.
    As to other things can cause it try split boost hose (common) or leaking intercooler (not uncommon).
  5. OP
    bembo449
    4,154
    1,285
    Jan 2, 2012
    Your Mercedes:
    ok understood LK , I would have thought that I would see a reaction form the exhaust if there was a split of some kind but its free to check ;)
Share This Page
