4-Pot SL43 AMG Press Release
KillerHERTZ
Cambridge
www.youtube.com
W463 G55 AMG
Apr 6, 2022
Affalterbach
Electric exhaust gas turbocharger derived directly from Formula 1™ for the first time in a production vehicle
Affalterbach. Following the two variants with V8 engines, Mercedes-AMG presents the SL 43 (combined fuel consumption 9.4-8.9 l/100 km, combined CO2 emissions 214-201 g/km),[1] a technically innovative entry-level model of the newly developed roadster icon. Under the bonnet of the open-top 2+2-seater with fabric soft top is an in-line four-cylinder petrol engine with two litres displacement that provides the befitting propulsion. This is the first time in the world that an electric exhaust gas turbocharger is being used in a production vehicle. This technology comes from Formula 1™. The system in the SL 43 is a direct derivative of the development successfully used by the Mercedes-AMG Petronas F1 Team for many years in the premier class of motorsport. The new form of turbocharging guarantees particularly spontaneous throttle response across the entire rev range, thereby offering an even more dynamic driving experience while increasing efficiency at the same time. The turbocharger is operated via the 48-volt electrical system, which also feeds the belt-driven starter-generator (RSG). As a result, the Mercedes-AMG SL 43 has an output of 280 kW (381 hp) and a maximum torque of 480 Nm, plus an additional short-term boost of 10 kW (14 hp) from the RSG in certain driving situations. The new entry-level model in the SL family also shines with extensive standard equipment. In addition, numerous options that enhance comfort and safety offer a wide range of possibilities for individualisation.
In the 70 years of its development history, the SL experienced the transformation from a thoroughbred racing car to an open-top luxury sports car - and has long enjoyed legend status, not least for this reason. The new Mercedes-AMG SL now marks another milestone in the model's history. It combines the distinct sportiness of the original SL with the unique luxury and technological excellence of the modern Mercedes-AMG models. As the new entry-level model in the series, the SL 43 is a particularly good example of this. It is the world's first series-produced vehicle to feature an electric exhaust gas turbocharger. This technology comes directly from Formula 1™ and solves the trade-off between a small, fast responding supercharger that nevertheless achieves comparatively low peak power and a large supercharger with high peak power that only responds delayed. With its innovative engine concept, the new entry-level model of the 2+2-seater roadster is aimed more at particularly tech-savvy buyers. With its combination of a comparatively light four-cylinder engine on the front axle and rear-wheel drive, the SL 43 also displays distinctly discrete handling characteristics.
"In its long history, the SL has repeatedly set technological milestones. For example, while the legendary 300 SL Gullwing in 1954 was the world's first series-produced passenger car with direct petrol injection, the new Mercedes-AMG SL 43 is now the very first series-produced vehicle with an electric exhaust gas turbocharger. With this technology, the SL also has an outstanding performance range in its entry-level version. This means that our seemingly smallest SL combines the typical AMG Driving Performance with luxury and comfort at the absolute top level. What's more, with this innovative engine we are undoubtedly also appealing to a wider clientèle", says Philipp Schiemer, Chairman of the Board of Management of Mercedes‑AMG GmbH.
"The electric exhaust gas turbocharger is a fascinating example of the extensive transfer between Formula 1 technology and the development of production vehicles. In implementing this in conjunction with our powerful M139 four-cylinder, we were also able to draw on the enormous wealth of experience of our colleagues at Mercedes-AMG High Performance Powertrains. The technology increases agility and thus driving fun, while at the same time improving the efficiency of the drive system. We are pursuing ambitious goals with a view to our electrified future. Innovative components such as the electric exhaust gas turbocharger help us to achieve this", says Jochen Hermann, Chief Technical Officer of Mercedes‑AMG GmbH.
Electric exhaust gas turbocharger improves engine responsiveness
The operating principle of the electric exhaust gas turbocharger is based on the same technology used by the Mercedes-AMG Petronas F1 Team. An electric motor around four centimetres thin is integrated directly on the turbocharger shaft between the turbine wheel on the exhaust side and the compressor wheel on the intake side. Electronically controlled, this drives the shaft of the turbocharger directly and thus accelerates the compressor wheel before the exhaust gas stream starts to drive it conventionally.
This significantly improves immediate response from idle speed and across the entire engine speed range. The combustion engine responds even more spontaneously to accelerator pedal input, while the overall driving experience is more dynamic. In addition, the electrification of the turbocharger enables higher torque at low revs. This also increases agility and optimises acceleration from a standstill. Even when the driver takes their foot off the accelerator or applies the brakes, the technology of the electric turbocharger is able to maintain the boost pressure at all times. This ensures so that a continuous immediate response.
The turbocharger, which is operated via the 48-volt on-board electrical system, works at speeds of up to 170,000 rpm, which enables a very high airflow rate. The turbocharger, electric motor and power electronics are connected to the combustion engine's cooling circuit to create an optimal temperature environment at all times. In combination with the internally named M139 two-litre, in-line four-cylinder engine, the innovative technology in the SL 43 produces a rated output of 280 kW (381 hp) at 6750 rpm. The maximum torque of 480 Nm is available between 3250 rpm and 5000 rpm. Depending on the situation, the system also guarantees an additional boost of 10 kW (14 hp) for a short time from the belt-driven starter generator (RSG).
The second-generation RSG also functions as a mild hybrid in the 48-volt on-board electrical system, which in addition to the temporary power boost enables functions such as gliding mode and energy recovery for maximum efficiency. At the same time, the 48-volt technology also increases comfort, as the transitions between the start-stop function and the gliding mode function are almost imperceptible.
AMG SPEEDSHIFT MCT 9G transmission with wet start-off clutch and rear-wheel drive
The four-cylinder engine known as the M139, which has long been used transversely in Mercedes‑AMG compact models without an electric exhaust turbocharger, is positioned longitudinally in the SL 43. In the entry-level model in the SL series, which always features rear-wheel drive, it is also combined with the AMG SPEEDSHIFT MCT 9G transmission (MCT = Multi-Clutch Transmission) for the first time. A wet start-off clutch replaces the torque converter. It reduces weight and, thanks to its lower inertia, optimises response to accelerator pedal input, especially during spurts and load changes. The elaborately calibrated software ensures extremely short shift times as well as fast multiple downshifts if required. In addition, the intermediate throttle function in the "Sport" and "Sport+" driving modes delivers a particularly emotionally appealing gearshift experience. There is also the RACE START function, which ensures optimal acceleration from a standstill.
The driving performance is up to par: from a standstill, the SL 43 accelerates to 100 km/h in just 4.9 seconds if required, and the top speed is 275 km/h. In addition to the performance it offers, the entry-level model of the series is also distinguished by comparatively low consumption and emission figures.
KillerHERTZ
KillerHERTZ
Cambridge
www.youtube.com
W463 G55 AMG
  • #2
Driving assistance systems and MBUX: intelligent helpers in the background
With the aid of numerous sensors, cameras and radar, the driving assistance systems, some of which are optional, monitor the traffic and surroundings of the new SL 43. If necessary, the intelligent helpers can intervene at lightning speed. As in the current generations of the Mercedes C-Class and S-Class, the driver is supported by several new and enhanced systems. This is done in everyday situations, for example, by helping with speed adaptation, distance control, steering and lane changes. This makes it easier to react to impending collisions. The functioning of the systems is visualised by a new display concept in the instrument cluster.
The new assistance display in the instrument cluster shows comprehensibly and transparently how the driving assistance systems work in a full-screen view. The driver can see their car, lanes, lane markings and other road users such as cars, trucks and two-wheelers in an abstracted 3D way there. The system status and operation of the assistants are visualised in this depiction of the surroundings. The new, animated assistance display is based on a 3D scene generated in real time. This dynamic, high-quality representation makes the operation of the driving assistance systems transparent as an augmented reality driving experience.
Numerous connectivity services available
The MBUX (Mercedes-Benz User Experience) infotainment system enables extensive operating options and many digital services from Mercedes me connect. The strengths include the intuitive operating concept via touch screen or touch control buttons on the steering wheel, Smartphone Integration of Apple CarPlay and Android Auto as well as hands-free operation via Bluetooth connection and Digital Radio (DAB and DAB+). In conjunction with MBUX, customers already have access to connectivity services such as Live Traffic Information. Mercedes me connect makes the new SL altogether more intelligent: Additional functions can be used before and after the journey or while on the road. All that is required is to link the roadster to a Mercedes me account in the Mercedes me Portal and accept the Terms of Use. Thanks to navigation with Live Traffic Information and Car-to-X communication, the customer drives with real-time traffic data. This way, traffic jams can be avoided efficiently and valuable time can be saved. Networked vehicles exchange information about traffic events by means of car-to-x communication.
Technical data[1]
Mercedes-AMG SL 43
Engine
Number of cylinders/arrangement 4/in-line
Displacementcc1991
Rated outputkW/hp280/381
at engine speedrpm6750
Additional output (Boost)kW/hp10/14
Rated torqueNm480
at engine speedrpm3250-5000
Compression ratio 10.0
Mixture formation combined direct petrol injection and intake manifold injection, turbocharging by means of electrically assisted exhaust gas turbocharger
Power transmission
Drive system layout Rear-wheel drive
Transmission AMG SPEEDSHIFT MCT 9G (automatic transmission with wet multi-disc start-off clutch)
Gear ratios
1st/2nd/3rd/4th/5th/6th/7th/8th/9th gear 5.35/3.24/2.25/1.64/1.21/1.00/0.87/0.72/0.60
Reverse 4.80
Chassis
Front axleAMG RIDE CONTROL suspension with aluminium double wishbones, anti-squat and anti-dive geometry, lightweight coil springs and stabiliser bar
Rear axleAMG RIDE CONTROL suspension with aluminium double wishbones, anti-squat and anti-dive geometry, lightweight coil springs and stabiliser bar
Brake systemHydraulic dual-circuit brake system; 390 mm composite brake discs at front, vented and perforated, 6-piston aluminium fixed calliper; 360 mm composite brake discs at rear, vented and perforated, 1-piston aluminium floating calliper; electric parking brake, ABS, Brake Assist, 3-stage ESP®
SteeringElectromechanical speed-sensitive power steering with rack and pinion, variable steering ratio (12.8:1 at dead centre) and variable power assistance
Wheelsfront: 9.5 J x 19; rear: 11 J x 19
Tyresfront: 255/45 ZR 19; rear: 285/40 ZR 19
Dimensions and weights
Wheelbasemm2700
Front/rear trackmm1665/1629
Length/height/widthmm4705/1359/1915
Turning circlem12.84
Boot capacityl213-240
Kerb weight acc. to ECkg1810
Payloadkg335
Tank capacity/of which reservel70/10
Performance, consumption, emissions
Acceleration 0-100 km/hsec.4.9
Top speedkm/h275 (electronically limited)
Combined fuel consumption, WLTPl/100 km9.4-8.9
Combined CO2 emissions, WLTPg/km214-201
[1] The stated figures are the measured "WLTP CO₂ figures" in accordance with Article 2 No 3 Implementing Regulation (EU) 2017/1153. The fuel consumption figures were calculated on the basis of these figures.
rorywquin
North Yorkshire
An old B-Class.
..........and the all important question “How much will they cost and when will they be available? “
My son ordered a Taycan about 8 months ago for delivery in May. Now been pushed to late July.......
JBell
Torquey
C350 CDi Estate (GAD Edition)
That is one stunning colour :cool::cool::cool::cool::cool:
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
Nice looking car.
Quad exhaust tips on a 2 litre 4 pot is a bit sad though.
They should only appear on V6/8/12 to show there is something special under the bonnet. IMHO of course.
I would also be interested in the pricing.
Four cylinder?
An SL should be an iron fist in a velvet glove but with a 4 pot it's more iron fist in an alcantara glove.
SLs need a minimum of 6 cylinders to get the refinement associated with the model.
mioba
Nottingham and Köln
MB do design some lovely looking cars
AMGeed
Poole, Dorset
Four cylinder?
Inevitable really once Mercedes decided to plonk an electric motor and a 4 pot into the next line of C63's
It's all downhill now for big engines.:(
00slk
Cambridgeshire UK
Still can't beat the SL55 though :D
Have to agree, 4 cylinders in a Mercedes...nah!
There's nothing more disappointing than starting up a posh car and having no sound out the exhaust.......
sl500amgsport
Essex
SL500 2014
Four cylinder?
It's not even in a V formation and the output is certainly not worthy of 4x exhausts!
An embarrassment to the SL brand let alone AMG, an inditement of current times and may as well be all electric.
Sent from my SM-G988B using Tapatalk
At least they've gone sensible(ish) on the tyre sizes.
Conor
London, UK
So it does look great but I wouldn't be having a 4 pot.
I think I will also be skipping hybrids.. especially this type of performance oriented trickery.. So much to go wrong.
I suppose they have done the best they could. I mean their hands really are tied on this re powerplants, aren't they?
SmartAmg
2011 E class coupe 350 CDI
Lovely motor, gorgeous colour. :cool: :)
rorywquin
North Yorkshire
An old B-Class.
*only available in silver, black or white in the UK…:rolleyes:
OMG ---I’ve been showing my wife pictures of that car and she loves the colour. All she cares about in a car is colour (tick), ride comfort & space for her handbag and coat (tick).
2/3 ....so close - had many silver & white & don’t want a black car so that’s me gone. :(
rorywquin
North Yorkshire
An old B-Class.
They fixed that in the SL400 facelift -- exhaust noise generator in the boot...:rolleyes:
Kev555
N.I
Four cylinder?
All to do with save the earth campaigns, global warming etc. Big pressure from governments on car companies to get rid of V6 upwards engines. Grab your 6 and 8 pots while we still can as eventually and this is only my own assumption that we may not be allowed to drive at all or limited miles and face an even more hefty road tax bill at some point. Ford for one example bowing to Gov and environmental pressure in America agreed to build one Mustang E for every three petrol Mustangs. Worked out better for them now as lot of Americans complaining about four dollars per gallon atm. Bring them over here for a week then they would have something to bitch about.
Less drag and weight.
At least with a 4 pot in the front it should handle well, nice and light
An R230 SL500 V8 with a folding metal roof is 1,745 kg
This ecomentalist il4 with a rag top is 1,810 kg
What's the reverse of progress... :rolleyes:
