500 SEC rear window switch
coolhans
Keynsham, Bristol
Present 2004 W211 E500, 1995 W124 E320 CE Coupe.
Can anyone help me? I have a problem with the rear window switch on my recently acquired SEC. This is the switch in the rear of the car not in the centre console. When I bought the car although the rear window would go up and down from the front, it would only go down in the back. I ordered a second hand switch from Dronsfields prior to dismantling the old one but it wasn't exactly the same. The replacement had pins which I presume would plug into some kind of socket but the original (which I damaged removing) had a small loom wired to it leading to a junction box behind the side trim. The trouble I'm having is I would like to know how to remove the switch on the other side without damaging it. I want to get the part number from it, so I can order the correct switch. Is there anyway to access it without removing the entire interior trim which seems a lot of work. Thanks in advance.
Where abouts is it in the car
coolhans
coolhans
Keynsham, Bristol
The switch is in the rear of the car on the right hand side in the passenger grip.
Then have a go with this guy,,he is a very good forum member
robparker robparker is offline
__________________
Three Pointed Parts- Mercedes used and new spares.
cars currently in for breaking include:
190e 2.0 x2
190e 1.8
E300TD 210
E230 210
E320 210
300se 126 x2
500sel 126
560sec 126
c180 202
c220 202
c250d 202
300ce-24 124
300te-24 124 x2
E280 124
300te-4matic 124
300e 4matic 124
300d 124 x2
320te 124
230te 124 x3
280e 124
250TD 124
450sel 116
280te 123
s500 140
c200 201
c220 201 x2
He is in the spares section
coolhans
coolhans
Keynsham, Bristol
Thanks very much I'll give him a try.
