coolhans
- Jul 17, 2009
- Location
- Keynsham, Bristol
- Present 2004 W211 E500, 1995 W124 E320 CE Coupe.
Can anyone help me? I have a problem with the rear window switch on my recently acquired SEC. This is the switch in the rear of the car not in the centre console. When I bought the car although the rear window would go up and down from the front, it would only go down in the back. I ordered a second hand switch from Dronsfields prior to dismantling the old one but it wasn't exactly the same. The replacement had pins which I presume would plug into some kind of socket but the original (which I damaged removing) had a small loom wired to it leading to a junction box behind the side trim. The trouble I'm having is I would like to know how to remove the switch on the other side without damaging it. I want to get the part number from it, so I can order the correct switch. Is there anyway to access it without removing the entire interior trim which seems a lot of work. Thanks in advance.
