All MB wheels have a stud pattern which is identical, you need to watch the offsets and wheel widths.
I believe every MB apart from the R129s and W126s have an offset of between 30 and 40 (usually 37 if memory serves), the SL's and certainly the SECs (Not sure about the SE or SEL from the W126 series) have an offset of 25.
This causes real problems replacing the wheels on the SL/SEC without spending a fortune.
The wheel specs (Width and offset) should be stamped onto the wheel. If these are similar to the W124 spec wheels (6.5J x 15 ET 37 again if memory serves) you should be OK.
Of course you could always try one on the car and see!
