500SL Engine Miss
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by mikemartin1939, Nov 29, 2012.
  1. mikemartin1939
    mikemartin1939 Member
    22
    Nov 29, 2012
    Palmyra, VA
    Your Mercedes:
    500SL/1991/8 cyl- SL500/1999/8 cyl
    1991 500Sl that after about 15-20 miles starts to hiccup. Slow at first but gets progressively worse. Added fuel dryer to tank but it made no difference. Seems as if the problem is heat related. Any help would be greatly appreciated.
  2. WG M-B
    WG M-B Senior Member Authorised Forum Supporter
    3,105
    6
    Dec 5, 2010
    North west london
    Your Mercedes:
    C63 Wagon in black
    Sounds like moisture in the distributor caps. Very common
  3. Fleetwood
    Fleetwood Senior Member
    163
    Jun 20, 2012
    Horsham, West Sussex
    Your Mercedes:
    2005. SL350
    I second the moisture in the dizzy cap
    Remove the caps and give them a good clean, you should be able to see if there is any tracking of the spark
    Check for cracks and replace if there is any
  4. OP
    mikemartin1939
    22
    Nov 29, 2012
    Palmyra, VA
    Your Mercedes:
    I have worked my way to the dizzy caps, right and left. Not much slack in the plug wires so should I just pull them straight off to get the caps off? Anything to look out for in the cap removal after I loosen the 3 allen head bolts?
    The plug wires at the caps and where they rub against each other look as if the might have some fine white ash-like powder where they are in contact with each other. Going to check it after it gets good and dark to see if there is any arcing.
    Thanks for all your help.
  5. Alex Crow
    Alex Crow Senior Member
    10,677
    34
    Jul 9, 2009
    Super Suffolk
    Your Mercedes:
    As above +3
    If you do find moisture in them, but they otherwise look OK it is your lucky day.
    Dry them out properly - and a little cheat - spray liberally inside the cap and the arm and back plate with silicone spray, it works wonders.
    I would not worry so much about the leads at this point, they cause little trouble on these in general.
  6. OP
    mikemartin1939
    22
    Nov 29, 2012
    Palmyra, VA
    Your Mercedes:
    Caps had no moisture inside or any apparent tracks. All interior electrical contact points on both caps and rotors are very badly pitted and burned. Ordered new caps and rotors and will advise of results after replacing and a good long test drive.
  7. television
    television Always remembered RIP
    164,074
    310
    Your Mercedes:
    Do spray the new ones, silicon is very good and elecrically perfect, it will stop the tracking, do the caps as well
  8. lanciaman
    lanciaman Senior Member
    711
    3
    Sep 25, 2009
    Aberdeenshire
    Your Mercedes:
    E220 Cabrio (A124) - 1994
  9. television
    164,074
    310
    Your Mercedes:
    Yes and perfect, the coating electrical resistance is not measurable
  10. OP
    mikemartin1939
    22
    Nov 29, 2012
    Palmyra, VA
    Your Mercedes:
    Received the new caps and rotors 10 minutes after my last post. Replaced all, sprayed silicone and did a 31 mile test drive. Put my foot in it numerous times without a hiccup. Don't want to get too cockey but it looks as if the problem may be solved. Thanks too all for your assistance and confidence building.
  11. lanciaman
    711
    3
    Sep 25, 2009
    Aberdeenshire
    Your Mercedes:
    Malcolm, one thing. Light or liberal coating, and how often?
    thanks
  12. jonthetourist
    jonthetourist Senior Member
    256
    Jan 9, 2005
    Glos
    Your Mercedes:
    1991 SL300-24
    I know it was addressed to Malcolm, but I would vote for very September, just before the cold and damp sets in.
    Jon (fellow sufferer)
  13. lanciaman
    711
    3
    Sep 25, 2009
    Aberdeenshire
    Your Mercedes:
    Thanks Jon. I love the way a £400 cap and rotor set counts as a consumable!! Or £250 if you get from ECP...
  14. OP
    mikemartin1939
    22
    Nov 29, 2012
    Palmyra, VA
    Your Mercedes:
    The new cap and rotor pair that I got on Ebay was $178.60. Manufacturer was Bremi of Germany. Perfect fit and operation.
Share This Page
