56 RPM Cut off w124 E 320 5 auto
The car sounded normal to me
A
anas2912
A
anas2912
Iam warry beause of wiring of the throttle may be not fully opened
type49
I assume you mean at 5600RPM, the gearbox changes up a gear when you want it to hold on a bit longer? This is only slightly under, as these should change at 6000RPM, not 6500. Either way, probably only a minor adjustment. Either kickdown switch is not working correctly, throttle adjustment wrong (not getting full throttle), or, most likely, gearbox control cable not adjusted properly. Look for the cable going down to the gearbox from the throttle housing. Now move the throttle slightly with your hand & look for a black plastic "pointer/arrow" which moves about. The points ( >< ) should be together with no throttle. If they are slightly out, then adjust the cable with a 13mm spanner.
A
anas2912
cheked by otech. Bosch Diagnostic I tgoudht the error name was speed sensor !!
A
anas2912
You are right because if the car at parking it reaches the red line
I will do what you mention to me and try your solution
Thanks a lot
A
anas2912
Now my car reach around 6500 RPM
Simply I solve the abs problem and this problem solved
