380560
- Jul 22, 2008
- Location
- Isle of Skye Highlands
- S Class, W140 4.2 Limo, Nissan 300ZX twin turbo, Porsche 911.
I believe i need a height control valve/ lever which controls the self levelling rear suspension on my 1988 E reg 560 sec. Currently the rear suspension is too low and i occationally can hear a rubbing/ bottoming out sound when driven reasonably hard or just pulling away from a stand still, subsequently the front head lights are too high. If i can not find a valve is there an alternative solution to remedy this problem to lift the rear suspension?
Also what hydraulic pipe gauge i required to this valve please, cab standard 3/16 brake pipe be fitted? If not where can i bu the correct ppr?
I have been advised that the Mercedes Benz part number MAY be 2023200258? Can anyone PLEASE help me as I can not locate one. A used working example would be fine so long as there are no leaks etc. I have been advised that a 380 SE/SEL will NOT fit/ work correctly, purhaps some one an confirm this? I have placed a wanted ad in the spares section, but any help/ advice would be most grateful. I can be contacted on 07917 757433 or via this medium. Thanks in advance.
