560 SEC Water leak
44239
doncaster
Hi,i was out in my pride and joy yesterday and was caught in what can only be described as a monsoon.To my complete horror i found that the drivers side rear footwell was an inch deep in water when i got home.Where do i look to try and sort this? I have restored Range Rovers in the past,i can weld,is the job worth trying myself?.The door seal on the drivers side is split on the curve of the door,but the only damp is in the footwell.To say i am gutted is an understatment.Thanks for looking,regards LES.
lepton
Mid Sussex
Water appearing in the rear footwell can originate from a leak in the front of the car. It is carried through a wiring channel under the front carpet and barely wets the front. In my case the drain holes in the firewall below the windscreen were blocked and the subsequent corrosion had created an entry point for water. There are several recent threads on leaks.
Alan
doncaster
Thanks for that Alan,i guess i know what i will be doing this weekend.Regards Les.
your heater air box could be blocked with leaves and debri and the drain tubes for the sun roof can get blocked.
Malcolm
Mikesmerc
Co.Cork IRL
2001 CL500,1990 560SEC, 1988 230E, 1982 250, 1979 280CE, 1977 200D, 1972 350 SL, 1965 220S Fintail
Might have a look at the rear window rubber, this can fail and lead to some unseen nasty corrosion beneath. Should be visable if you look under the rear parcel shelf from the boot side. My 560SEC suffers badly from this, not sure if the water ever reached the footwells but certainly flooded the boot.
Rgds
Mike
