560 sel
Status
Not open for further replies.
Dhanda
Wolverhampton
w221 320l cdi 2006
Can anyone help me diagnose a clunking sound from front end when going over rough roads or drains.
I've also got an annoying miss on idle only, no hesitation on pull away. Have checked leads, plugs, fuel filter, dizzy cap, rotor arm, vac lines.
Futher suggestions needed
Malcolm Brown
Macclesfield, Cheshire
www.******************.co.uk
Three areas to look at with the clunking noise are anti-roll bar bushes, idler arm bushes and the balljoints in the 'brake support links' (also known as steering support links).
These balljoints (LH & RH) sit in big lumps of metal fixed by 2 large bushes/bolts to the chassis. They should be easy to spot just aft of the front wheels. There is a repair kit for the balljoint.
D
Dhanda
Wolverhampton
w221 320l cdi 2006
Thank you for your suggestions, I will check the big bushes. 8)
Status
