560sec Fuel filter location?
Status
Not open for further replies.
Mikesmerc
Co.Cork IRL
2001 CL500,1990 560SEC, 1988 230E, 1982 250, 1979 280CE, 1977 200D, 1972 350 SL, 1965 220S Fintail
I think my 1990 560sec is experiencing a fuel shortage. It wears down the battery trying to start it and when started it does not respond to the accelerator very well it seems to stall. I had a quick look around the engine bay for an inline filter but couldnt see any on the lines. Another thing I noticed is when the ignition is turned on the fuel pump can be heard running which normaly cuts out shortly afterwards but sometimes keeps running until I turn the ignition off. Could this be the reason for the poor start up?
Any comments/suggestions would be greatfully appreciated.
Regards
Mike
Spike
London
1999 SL500
Not sure about an SEC but on many MB's the pump and filter is located under a plastic panel under the car around the offside passenger footwell area. Big things they are..
A known issue with many models is the fuel pump relay so it may be worth checking the relay first.
M
Mikesmerc
Co.Cork IRL
Cheers Spike that could just be the problem, just to find the relay now.
Regards
Mike
M
Mikesmerc
Co.Cork IRL
Fuel seems to be getting to distributor under air filter when ignition is turned on. Does this eliminate faulty relay?
Already posted a fuel trouble shooting question, just awaiting a reply.
Cheers Spike
Status
