6310i Nokia Phone in S320l CDi
TOMROB53
Oxon
2002 E320 2002 Estate W210
After rummaging around in some of those cupboards in the house (where angels fear to tread !!) I found the above phone and thought that looks like it will fit into the cradle in the armrest of the car, it did, but now all |I get is a message saying "Tel Initialising" on the command screen.
I have checked the cradle and the phone charges up in it but doesnt want to connect to the command unit, there also doesnt seem to be any cables from the cradle going into any part of the car, but I cant understand why the phone charges if this is not the case, any ideas anyone ?
T
TOMROB53
Oxon
  • #2
Also the satnav doesnt display the map could the two things be connected to the aerial ?
Dec
Ireland.
W202
On the back of the phone, is there a rubber bung? if there is, it needs to be removed.
Dec
eGuru
Northants
www.artguru.co.uk
C180 S204, S320 CDi
On the 2002 model the Nokia 6210 comes as standard. Although the 6310i uses the same cradle you need to replace the PSE, phone controller, to be able to use this phone. The PSE is located under the passenger seat.
giuseppe
Bournemouth
E220Cdi avantgaurde 2001
what's a PSE
2 things here, the phone must have software 5.5 or it will not find it,,, some early cradles did not like the 6310i and this was a 2002 problem
Anyone can take their 6310i and have the software upgraded to 5.5 and cradles are on Ebay circa £30
Correct, but still wont work with the 6210 PSE unit:(
Well my 2002 car will take will take the 6150,6210 and the 6310i the only part that had to be changed on my car was the cradle, for which there is a modified one, this is a listed fault within WIS and nothing else to change. the controller stays the same
Dazzler
Haverhill, Suffolk
W211 E320 CDi Estate 05
Can i borrow your modded cradle then Malcolm:roll::razz:
Dazzler
Haverhill, Suffolk
Do you happen to know the part number for the modified cradle??
The actual wording in my book say that the phone is installed for £xxx and the cradle is ordered as an accessory I do have the info somewhere and I will try and find it,,I did post it all in 2006 but I cant find it here
I found this on an old thread of mine
the cradle 67875846 takes the 6220-6230-6230i
T
TOMROB53
Oxon
Thanks everyone for the replies, sorry havent been able to respond earlier as I now have a PC problem to contend with as my computer went phut last weekend, once I regain full computer powers I will be able to concentrate on getting phone sorted out !!
Hi malcolm, how does one upgrade to 5.5
I use a small back street phone shop,, the big boys cannot do it,,it takes one hour and cost £10
giuseppe
Bournemouth
will it work on the 6310i model
www.ckinsurance.co.uk
