ALFIEBEARD
- Mar 2, 2009
- Age
- 70
- Location
- DUMFRIES
- JAGUAR XF-R SPORT
Hi Chaps,
As most of you are aware I have been pestering Malcolm (televison) and a few others concerning late changes etc on my E211 2004 5 speed Autobox, Malcolm kindly sent me a link from a guy in Seattle who had the following information on how to Reset the gearbox to Crisp mode as he called it, I followed his advice to the letter and can confirm my car now changes gear perfectly and at the correct engine revs, its worked brilliantly for me so here is the procedure should you want to give it a go:-
(1) switch OFF the climate control and radio.
(2) close ALL doors.
(3)Turn Ignition key to all dash lights ON position(not as far as start though)
(4) Press and hold the accelerator to the floor for 20 seconds.
(5)with Accelerator still to the floor, turn the key to the OFF position DONT REMOVE IT YET.
(6) Slowly lift your foot off the accelerator.
(7) Sit for 2 minutes DONT TOUCH ANY SWITCHES.
(8) Remove the ignition key and exit the car.
I left the car overnight then drove it the next morning but this is,nt nessesary you can get in and try it after a couple of minutes.
I can honestly say this works and has set the shift points to the perfect settings.
Hope this helps someone else as it has helped me, and Thanks Malcolm once again for the link.
Alfie B
Alfie B
