Jim2
- Jan 18, 2018
- 1st Merc 2010 E Class W212 2.1 CDI. 2nd Merc 2014 E Class W212 220 CDI
When I check the fluid level in the 722.6 5 speed transmission in my w212, the black plastic end on the dipstick "flexes" a little bit when it hits the bottom of the sump. This "Flex" would be between 1/8" and 3/16's " Max 1/4" . So I "juggle" it a little bit to what I think is the correct position. I then fixed a hard rubber washer on the dipstick, right at the top of the metal dipstick tube, so that it cannot go any deeper or "flex". I think that it is now stopping at the correct position in the sump ( At least I hope that it is.... ). My question to the forum is, has anyone ever pushed a different kind of cable or tube down into the sump ( one that will not flex at the end tip, and will stop when reaches the bottom of the sump ) then measured the oil level in inches or Centimeters? I have attached 2 pics to show what I mean. I am really checking the accuracy of the dipstick that I am using, because the fluid level in these transmission's is really critical for good performance, and a flex of a 1/4" is not very accurate. ( BTW, the stick is supplied by Febi Bilstein, so I guess it should be OK .)
